hello.. I have some problems with recording... I oush on the rec. button but nothing happens.. :'( wtf is the problem..??
HEEEEEELP!
Dj Cash
HEEEEEELP!
Dj Cash
geposted Sat 19 Mar 05 @ 12:07 pm
Please complete your profile or post your PC spec. (especially your sound config). This way we would be more able to help you.
geposted Sat 19 Mar 05 @ 3:05 pm
okey... I have a laptop (HP) 1.4 ghz 480mb ram 40 gb harddisc a Hercules Dj console and I use it as a soundcard too... is it enough..??
Thnx for replying
Dj Cash
Thnx for replying
Dj Cash
geposted Sat 19 Mar 05 @ 3:57 pm
check if the lame encoder path is set correct in Virtual DJ settings
geposted Sat 19 Mar 05 @ 4:32 pm
how can I check it..? (hva går jeg inn på? :p)
geposted Mon 21 Mar 05 @ 10:13 am
If you record in mp3, you need to download the "lame encoder" (you can find it on internet), put it in a folder, and than specify a path under settings > plugins > mp3 encoder. If you record in wave, it should work normally without needed codecs for compression.
geposted Mon 21 Mar 05 @ 10:26 am
