I've got a Herc. Dj Console and the VDJ software that came with it, and whenever I'm using VDJ after only a short time, I will get garbling of the folder and file names in the browser.
The names will start overlapping each other, disappearing, and otherwise becoming garbled which makes it pretty much impossible to use for an extended period of time.
Has anyone else had problems like this or know what the problem is?
I have a p4 2.8ghz windows xp, latest directx, a toshiba satellite p25-s507, with an nvedia 5200go graphics card.
So, I can't understand why I have this powerhouse of a laptop and VDJ which is the primary software bundled with the DJ Console, and basically the only good software that won't work
Moderated by Lady Cameron
Sorry krazyk no email address is allowed from a demo user
geposted Sat 19 Mar 05 @ 12:09 pm
Register your Hercules console in your profile under "detect console", and you'll be able to download fixes/updates for your version of VDJ.
geposted Sat 19 Mar 05 @ 12:25 pm
sounds like a problem with skin or graphic card...
Try different skin, and make sure graphic card does not have an IRQ sharing with soundcard,
geposted Sat 19 Mar 05 @ 4:20 pm
I downloaded the update for the hercules console for vdj, which is freely availiable just by registering, and that fixed the problem. So, if any other herc users have the same problem, make sure you download the update.
Thanks
Thanks
geposted Mon 21 Mar 05 @ 9:56 am
