Last night i tried out my new Mackie Speakers. approx 16 inches high 10 inchs wide and only weighing in at 9.8 kg with a whopping sound spec of max output of 1200 w per speaker, the sound was fantastic as most owners of this make already experienced, however a first for me. So small and convenient to lug around, well pleased.
geposted Fri 22 May 09 @ 12:02 am
"Mackie" is pretty general. What speaker model are you talking about?
geposted Fri 22 May 09 @ 1:01 am
sorry, Mackie Monitor 8 Industrial range
geposted Fri 22 May 09 @ 1:09 am
Im a bit confused by the fact you mention 'monitor'...
are you going to use these inside a DJ booth, to get a bit more clarity out of a club sound system (while you mix)
or are you hoping to get a big sound in a big room from tiny speakers??
geposted Fri 22 May 09 @ 11:02 am
If this is your speaker...
http://www.americanmusical.com/Item--i-MAC-MR8-LIST?SRC=D0501PG0HAMS0000&utm_source=pricegrabber&utm_medium=feed&
then i wouldnt use them anywhere bigger than my living room. (sorry)
geposted Fri 22 May 09 @ 11:05 am
Noooooooooo these
geposted Fri 22 May 09 @ 11:27 am
They look good, id use them in a small to medium room, but a bass bin would definately help them out..
geposted Fri 22 May 09 @ 11:33 am
chriso710 wrote :
Noooooooooo these
I think there be the ones we have in the booth at the club I play out. Small but surprising good indeed
Thumbs up from me.
geposted Fri 22 May 09 @ 11:39 am
consider these, too...
http://www.americanmusical.com/Item--i-MAC-C200-LIST
geposted Fri 22 May 09 @ 11:45 am
I have used the "mackies" as well before for weddings and other events that didn't require HUGE sound. They are very efficient and the sound is simply amazing. I have never heard such a little speak create such full sound.
geposted Fri 22 May 09 @ 1:36 pm
Sounds great. A DJ I work with talked of the mackie Bass bins, I will check them out. Because my regular Venues are of different size I am trying out for the accoustic variation with these, with tonight and last nights gigs I am well pleased. Im always happy to hear others opinion, thanks guys .
geposted Fri 22 May 09 @ 7:13 pm
