Hey Ya
I have the numark virtual vinyl 5 hardware and software that i use with a external mixer and decks that doesnt control the mixer on the software which is fine
but to record and broadcast i understand i need a mixer that will control the virtual vinyl software ?
so looking for sugestions of what mixer to get that will control the vdj mixer so i can broadcast and record not wanting to spend anymore than £200 ish really
need to be able to plug my decks and also my speakers into the mixer
bit confused of what i need so any help plzzzz
Just to add i need it to work with Vista
geposted Fri 22 May 09 @ 8:40 pm
No not really.
All you will need is a mixer that has a "booth out" option. You then can run a RCA from the mixers "booth out" to a internal soundcard. Then use something like Audacity (free software) to record the mix. This is how I record a mix when I use my TCV at home.
To Broadcast it's a similar set up too.
geposted Sat 23 May 09 @ 3:34 am
Thanxs for your reply
just looked at the mixer i got at the mo and the only bit that hasnt got anything plugged in is record out is that the same as booth out ?
also i use a laptop and dont have anywhere to plug into my soundcard so would i need a like usb sound card
geposted Sat 23 May 09 @ 6:03 am
I think that should do.
What I do is use is the internal soundcard of my old gig laptop to record with. I plug the RCA cable into the "Mic in" socket. So I think you should use that too.
geposted Sat 23 May 09 @ 6:27 am
i know what ya on bout now i used to do that before i was using timecode to record but the sound quality aint as good as if it was recording/broadcastin on Virtual Vinyl which is why im thinkin gettin a new mixer its just which one lol
geposted Sat 23 May 09 @ 6:39 am
Would the Numark DXM01 USB Mixer control the internal mixer on virtual vinyl ?
geposted Sun 24 May 09 @ 10:02 am
The DMX01 USB mixer is not midi compatible. The sound will be effected but not the fader on the skin.
geposted Sun 24 May 09 @ 11:14 am
Thanxs for reply can ya tell me a mixer that would work the fader in virtual vinyl one that i can connect my decks and also speakers too and headphones
geposted Sun 24 May 09 @ 12:39 pm
You can use midi controller such as numark total control, herc rmx or mk2 etc.
Also you can look at midi mixer.
Regards;)
geposted Sun 24 May 09 @ 3:48 pm
Regards;)
Regards;)
The Numark Total Control dont think it has anywhere i could plug my decks into not over keen on the others i just kinda want one thats like a simple kinda mixer like the Numark DXM01
geposted Sun 24 May 09 @ 8:14 pm
What about something like this this
It's probably the cheapest mixer with midi you can buy, and I think there is a design limitations when it comes to mixing video, ( I believe) but this will allow you to control VirtualDJ's fader and sliders.
geposted Mon 25 May 09 @ 2:28 am
