Hi, I recently got virtual DJ 5.2 and I set a skin at a higher resolution than my screen. I want to change it back to the 1024x768 skins but I can't get into Config because it's kinda... off the screen.
Regards
Oliver
Regards
Oliver
geposted Mon 25 May 09 @ 1:48 am
If u remember the skin you were trying to use and its resolution you can simply resize your desktop to that skins resolution to open it then change to a skin with 1024X768 OR you can go to MyDocuments/Virtualdj/Skins and delete all the skins that arent default and VDJ will go back to the default skin:)
geposted Mon 25 May 09 @ 4:13 am
1, goto my computer
2, go into c drive
3, go into programme files
4, go into your cue le folder or your virtual dj folder (depending on what your having the error with)
5, right click on the cue or virtual dj exe file and click properties
6, goto the compatabilty tab and make sure everything is NOT selected
7, if you had to deselect a box press apply and ok and exit
8, now try to open your programme again......
2, go into c drive
geposted Fri 28 Aug 09 @ 4:34 pm
