I just purchased the BCD2000 and it works fine with virtual Dj except for the static noise that keeps popping up. The sounds comes out clean and there is no distortion, but when I load up a song in channel B, static noise starts to come out.
Can anyone shed some light on this problem?
geposted Mon 25 May 09 @ 7:53 pm
It sounds like a latency issue have you got all the vdj settings to default also is the bcd2000 built in sound card asio and can you change the latency within the bcd2000s software control panel. I had one of these a few years ago and cannot remember how the software works but if you refresh my memory i will help you as i had a couple of problems getting this to work flawless but i do remember there was a driver update on the behringer website which helped a couple of things
geposted Tue 26 May 09 @ 4:12 am
bonjour
Exactly +1
An update of drivers BCD2000 Version 1.1.1.0 (952KB)
http://www.behringer.com/EN/Support/B-Control-Downloads.aspx
Sorry but it is in French (blog)
http://fr.virtualdj.com/homepage/limol/blogs/2757/Manuel__Configuration__Manipulation_des_Boutons_de_la__BCD2000_et_BCD3000___VDJ_en_Fran_ais.html
Exactly +1
geposted Wed 27 May 09 @ 8:04 am
