I have a RMX and Virtual DJ.
When I press play, on some songs, if doesnt start when i want it to.
Its not latency, it either jumps forward or jumps back?
Anyone else had the same problem?
Cheers
Gareth
Cheers
Gareth
geposted Tue 26 May 09 @ 2:52 pm
It sounds like you've enabled smart play (I think)
geposted Tue 26 May 09 @ 3:04 pm
Possible link to Sync button? Try re-mapping your cue-play button.
It sounds like its trying to match the beats according to the beat grid...
geposted Wed 27 May 09 @ 1:40 am
Its nothing to do with smart beat.
And how do you remap a RMX?
its really starting to piss me off, because its jumping and its giving me a shit begining to songs, so its not a clean mix.
Much appreciate it if any of you can help
geposted Wed 27 May 09 @ 1:56 pm
It seems like Beatlock enabled. Turn it off.
geposted Wed 27 May 09 @ 2:08 pm
You are using the Limited Edition ... you can not re-map the controller ...
The problem is that Smart Play is enabled. On the skin by the play buttons is there a green colored dot ? Click on it so it's not green.
geposted Wed 27 May 09 @ 2:20 pm
