HI IM POSTING THIS AFTER MEMORIAL DAY. I HAVE VIRTUAL DJ AND VIRTUAL DJ TIMECODE VINYLS. I HAVE A DELTA 44 WITH 4 INPUTS AND 4 OUTPUTS. I ALWAYS GET CUT OFF DURING THE MIX LIKE STOPS WORKING. I CONFIGURED EVERYTHING CORRECTLY. I HAVE OLDER NEEDLES BUT THEY ARE ORTOPHON CONCORDS ONE OF THE BEST NEEDLES FOR TURNTABLES. I WAS WONDERING THIS. DO I NEED A PHONO PRE AMP? LIKE CONNECT TURNTABLE RED AND WHITE TO A PRE AMP AND THEN OUT TO THE DELTA 44 SOUND CARD. I UNDERSTAND YOU CAN USE A SOUNDCARD LIKE A SERATO BOX OR FINAL SCRATCH BOX BUT IT HAS NO AMPS. ANY HELP WOULD BE GREAT. IM EITHER SWITCHING TO THE NEW NATIVE INSTRUMENTS TRACKTOR SCRATCH DUO. WHICH IS A SMALLER VERSION OF ITS PREDASSESOR OR STICKING WITH VIRTUAL DJ. PLEASE REPLY. I DONT WANT TO GO BUY PRE AMPS THO AT RADIO SSHACK ITS ITS NOT THE PROBLEM.
THANKS LOGIC
THANKS LOGIC
geposted Wed 27 May 09 @ 5:43 pm
The problem is that you need to invest some $$ in VirtualDJ ....
geposted Wed 27 May 09 @ 8:54 pm
