ive got serato but i dont like it as much as vdj le becuase it has no effects and so on my question is before i upgrade to the vdj pro version is it going to be a waste of money becuase my computor is only 1.6ghz ,it does have 2gig's of ram. when i had the trail version one platter would go crazy when it was stoped. second question if i do buy the pro version will i be able to put it on my new computor 6 months from now of course i will get one that has the recomended specs or shold i wait?. thanks
geposted Thu 28 May 09 @ 11:40 am
yes u can buy it now..the license lets you have it on as many CPU's as u want as long as they are not being used at the same time...;)
geposted Thu 28 May 09 @ 11:45 am
The license allow for 2 installs at the same time on two machines that you own ... not as many as you want ...
If you get rid of a machine at a later date, simply uninstall the software before you get rid of it and then install the software on your new system.
geposted Thu 28 May 09 @ 12:02 pm
im doing it now thanks
geposted Thu 28 May 09 @ 12:11 pm
its worth it... thats more than enough to run audio... good luck!
geposted Thu 28 May 09 @ 12:18 pm
its done now how do i get into the resererved forums? man my girl is goint to kill me lol
geposted Thu 28 May 09 @ 12:27 pm
Welcome to the 'pro' family.
You can now download and run all the plugins, skins, etc..
But to see the reserved forums, you need to have 4 stars, Experienced Pro User.
You might get this in time, as you participate on the forums, and help others with your experience.
geposted Thu 28 May 09 @ 1:55 pm
welcome beardugo, i think you maybe after the plug in section, but your cursor over the download tab (to the right of products) and select which section you want to be in ie plugins then you have another sub section to choose from.
edit
damn forgot all about i made this sometime back for someone else, hope it helps...
edit
if you need help on anything else there is normally someone about that can oblige, but i got one or two tutorials in my blog you can look at or you can always check out the wiki, but if theres nothing there i can help with i'll make you a vid.
geposted Thu 28 May 09 @ 2:00 pm
beardugo wrote :
its done now
Nice one, and welcome.
Reserved forums..........what!!!!!!.......nobody told me, lol
geposted Thu 28 May 09 @ 2:11 pm
Welcome beardugo to the VDJ family. If your girlfriend gives you a hard time about spending the money tell her it's cheaper than playing golf, paintball, or going to stripclubs. If you need any help in the future there's a ton of great talent here in the forums to call on. I'm not nearly as smart as some of the guys but I can tell you the best shirt to wear with a particular pair of pants.
once again welcome. :^)
~R~
PS: Careful about asking JIMMYB for help after 8:00 PM. (He tips the bottle a bit and may naswer questions you didn't ask)
~R~
geposted Thu 28 May 09 @ 2:13 pm
lol...
geposted Thu 28 May 09 @ 2:20 pm
so how many post per star?
geposted Fri 29 May 09 @ 1:35 am
Im pretty sure its my mod discrepancy... the more you find out about the program, the more you can help new users on the forum, the more you post, = a possible "experienced pro user"
believe thats how it goes :)
geposted Fri 29 May 09 @ 8:38 am
Thats pretty much it - unless there are exceptional circumstances decided by a teamer, it generally seems to be by community contribution in one way or another - supporting users, plugins, skins and so on...
geposted Fri 29 May 09 @ 8:48 am
I've found the VDJ "stars awarded" are based on the following:
Contributions, Popularity, and Politics, pretty much like life in general.
geposted Fri 29 May 09 @ 9:52 am
Except in life it usually goes in the order of: (1) Power (the first being dependent on a lot of one or both of 2 & 3), (2) Politics, (3) Money (4) Popularity, (5) Other Peoples Perception of which of the 1st 4 you have, (6) a whole buch of other style over substance categories and then somewhere waaaaaaaaaaaaaaaaaaaay down here are actual good contributions!
geposted Sat 30 May 09 @ 6:30 am
thanks for the fyi
geposted Sat 30 May 09 @ 11:23 am
