I had most of my music backed up plus I have not FULLY switched over to Virtual so I'm okay for tomorrow's Wedding BUT, is all of my Virtual Folder info stored on my External? If so, I probably need to start from scratch, Is this Correct?
I can not access the old drive AT ALL UGGH. so getting my Virtual info is almost impossible off that particular drive, can anyone give me some tips? because all of my virtual folders are missing.
geposted Fri 29 May 09 @ 6:29 am
Unfortunately i think your right. The database which contains your music information (including virtual fodlers) is stored on the same drive as the music itself.
i.e. if you have music on C: drive then the database file for that music will also be on see. Likewise music on E: drive, database on E: drive.
Other than trying to get a specialist to recover data from you "dead" drive i can not think waht else to suggest other than start from scratch. :(
geposted Fri 29 May 09 @ 5:03 pm
