Has anyone had any problems with the screen going completely blank for a couple of seconds when using VDJ. It happens when doing different tasks and effects the external karaoke screen at the same time. When i first open the program it also happens, and if you change the size from small to full screen it also happens then. No other programs are effected, the laptop is a new Toshiba satellite and it has 4gb of ram.
geposted Fri 29 May 09 @ 7:25 am
Are you MAXIMISING the virtualdj window? If you do, then it will have issues with other explorer windows and will affect the video display.
There are 2 ways around this. You could change your desktop resolutoin to the same as the virtualdj skin you are using, or change your skin to one that is designed for your monitor.
but maximising is a known issue thats been discussed before in the past.
geposted Fri 29 May 09 @ 7:57 am
