hi
I've been trying to update to the herc steel driver package 2009 hdjs_1 .exe
but keep getting this error
have tried various times to get it to install but no good
i can go back to 2008 hdjs_4 .exe with out any problems and it works fine
has anybody come across this problem before or no of away around it
cheers aubs
cheers aubs
geposted Sun 31 May 09 @ 9:15 am
This problem occur because the previous driver were installed using another console model, and you are now trying to install the new driver using another console (in this case a DJ Steel), and some file of the previous installation are not being updated.
The solutions:
1) Install the driver using the previous DJ Console (if possible) or simply connecting both consoles.
2) Go to C:/Windows/System32/drivers folder and delete the following files:
- hdjbulk.sys
- hdjasiok.sys
- hdjmidi.sys
Once done, launch the installation again.
The solutions:
- hdjbulk.sys
- hdjasiok.sys
- hdjmidi.sys
geposted Mon 01 Jun 09 @ 8:48 am
thanks Dj phatso
i did as you suggested and updated the driver package using the herc mk11 instead
then afterwards plugged the dj steel in and then bingo it works a treat now !!
thanks again aubs
thanks again aubs
geposted Mon 01 Jun 09 @ 1:15 pm
