Hi,
i just updated to 6.0 and I am new to Vista as I have been working on Mac.
VDJ is asking that I go to config/browser and click fix to fix the C: database.
Where do I go in Vista to complete this action?
Thanks.
Thanks.
geposted Sun 31 May 09 @ 4:48 pm
It's in the VDJ interface .. Click on the Config button on the skin, then go to the tab labeled Browser ... the bottom section is the Database maintenance area ... you will find the Fix button there ...
geposted Sun 31 May 09 @ 5:08 pm
oh...that was easy.
Thanks so much for the quick reply.
Junito Perez
Junito Perez
geposted Sun 31 May 09 @ 5:28 pm
No Problem
geposted Sun 31 May 09 @ 6:28 pm
