Am i wrong in thinking that i have the Pro Edition of the software? Because when i go to the buy section it tells me i can upgrade to VDJ Pro for 49.99 I thought i already had it... :-)
And is this the reason why i can not find the Mac Beta version for download?
geposted Sun 31 May 09 @ 6:11 pm
You have Cue, not VDJ Pro. You will see a thread a few posts down on exactly the same topic.
https://virtualdj.com/forums/109670/General_Discussion/CUE_users_Version_6_update____.html
geposted Sun 31 May 09 @ 6:13 pm
You have Numark Cue, correct?
In that case, sadly, you will have to wait until Numark releases v.6.
geposted Sun 31 May 09 @ 6:14 pm
I hope Numark keeps up with the updates.
geposted Sun 31 May 09 @ 6:21 pm
Due to beta testing for the MacBook Pro 3 years ago, i didnt pay anything for Cue... I guess i cant complain paying 50.00 for VDJ... So the only thing this will do for me is eliminate the wait for Numark to release the new version?
Thats assuming they will continue to support Cue... Im guessing they eventually wont.
geposted Sun 31 May 09 @ 7:33 pm
I will buy this now if the Denon S3700 is natively supported, does anyone know if this was included??? Im about to send my new S3700 back to Pro Sound because as a midi controller it doesn't work well with my computer... If native support makes it run better then i would happily keep it because i love the look and feel of the unit... As a cd player its not even close in comparing to the Pioneer CDJ1000MK3.
geposted Sun 31 May 09 @ 7:50 pm
There are over 40 natively mapped controllers in v6 ... All Denon controllers, Pioneer CDJ400 - MEP 7000, and on and on
geposted Sun 31 May 09 @ 7:59 pm
I would wait a week check back here. They still have their updates and downloads section for Cue up.
http://www.numark.com/cue
I am hoping since it has not been taken down, they still support the product. If we dont see anything in the next week or so, it may be time to consider alternatives (at least for me.)
geposted Sun 31 May 09 @ 11:04 pm
We don't need 2 threads open on this topic -- continue any thoughts here -- https://virtualdj.com/forums/109670/x/
Topic Locked
Topic Locked
geposted Sun 31 May 09 @ 11:05 pm
