hi how r u guys can u plz answer me about the Suggestion Box
1st. how does it works (because it pick very co0l music from my DB )
2nd.on what base(rule )does it works?
thanks i hop that u can answer me fast
thanx guys vdj is really the ultimat powerfull prog
geposted Tue 22 Mar 05 @ 9:44 pm
Hi mate!!
Answer's:
1: The program is NOT PICKING the song to the Db itself!!!
But it appears what you are most playing!!
2: already answerd this!! lol The most played songs from you!!
But.......i never trust it!! Dont need it!!!
Hope i helped you out!
Answer's:
geposted Tue 22 Mar 05 @ 10:05 pm
Suggestion box is a great tool!....
It bases the suggestions on what you usually play/mix from the song you are currently playing and have been playing (gives you about 5 songs to go to lower bpm and about 15 songs to build up)
It does not actually build a good suggestion before you have played about 5 songs in a row.
After you have played that much, it gives you quality suggestions based on your history of mixing.
and i love it ;)
and i love it ;)
geposted Wed 23 Mar 05 @ 2:52 pm
wow this new feature sounds quite cool, when you run out of ideas early in the morning.
I will consider upgrade to full.
Is there a way to transfer this "know how" from one pc to other or to backup it somehow.
Btw. Could be a nice feature to upload this suggestions to a web and download/synchronize with others.... maybe an idea for next release.
geposted Thu 24 Mar 05 @ 2:21 pm
if you transfer the playlists generated by vdj and the history file, you would transfer the data needed to another pc :)
geposted Thu 24 Mar 05 @ 8:17 pm
