I use VDJ mainly for streaming and DJ'ing online. I notice with V6, it's still being shipped with a version of the lame_enc.dll encoder from 2004.
There is a newer version available for anyone who needs it here:
http://www.free-codecs.com/download/Lame_Encoder.htm
(You only need extract the lame_enc.dll file)
Just back up your old copy and replace the old version in the plug-in directory. I did this before the upgrade and had no problems, however V6 will overwrite the newer file, so do this after.
I am curious if I need to do this though, and how important it is to streaming quality / performance?
Cheers :)
Cheers :)
geposted Mon 01 Jun 09 @ 11:12 am
bump
geposted Wed 03 Jun 09 @ 10:43 am
Thanks it worked great..I down loaded the mp3 encoder and put it in its place then made sure the dj had the correct rout to find it mine was C:\users\[name]\My Documents\Virtualdj\Plugins this was with win.7 and all is working well.
geposted Sat 01 May 10 @ 8:35 pm
