I have a problem with the Faderstart new in V6. From left to right everthing is fine. But from right to left the Song starts to late on the Crossfader in Centerposition with full Volume.
geposted Mon 01 Jun 09 @ 1:08 pm
What is the VDJScript statement that you used ?
geposted Mon 01 Jun 09 @ 1:50 pm
I use no special script. Faderstart is enabled in Registry with the latest Version of the Registry Tool. i have this behavior with the internal Mixer and with Midi from Total Control.
geposted Mon 01 Jun 09 @ 2:29 pm
I can't see a fade start option
geposted Tue 02 Jun 09 @ 3:27 am
You can enable Faderstart Option with the latest Registry Tool V2.1 by DJ Cel. Download Link https://virtualdj.com/addons/2170/Registry_Tool.html
geposted Tue 02 Jun 09 @ 7:31 am
Would be nice to have fade start as an opton on the skin.
Some things i saw on the registry that i dont know what they are.
What is the Ask Skin?
Speedload - does this mean it will load faster?
Crossfader Hamster - What is this?
Video yv12bug - What is this?
geposted Tue 02 Jun 09 @ 12:21 pm
You guys really need to use the Wiki more ... :)
https://virtualdj.com/wiki/RegistryValues.html
And you can turn on and off fader start with the skin (if it is added) or a controller ...
https://virtualdj.com/wiki/VDJscript_verbs.html - search the page -> fader_start
geposted Tue 02 Jun 09 @ 12:24 pm
Yes I let it in my tool more for a debug reason (I'm sure a user will cry one day when he forgets it ON lol ). A bouton on the skin is indeed a solution and it's already possible to add it on your VDJ6 skin.
geposted Tue 02 Jun 09 @ 2:10 pm
So many possibilities that it's confusing! haha
So much to discover, so little time.
geposted Tue 02 Jun 09 @ 2:42 pm
Hi friends,
In vdj 6.0.1 the faderstart works for both decks. And in vdj 6.0.2 it works for the selected deck.
I tried it out just a sec. ago
best regards,
John
best regards,
John
geposted Sun 30 Aug 09 @ 2:15 am
Try SSLOVER v10, press option in the middle panel 3 times then you'll see Fader Start, select yes. I tried it before during the trial of v6 with same result as what you said. Left deck worked just fine but right deck seems so late, e.g middle of the x-fader.
geposted Sun 30 Aug 09 @ 3:18 am
