hey there,
I have just bought a mixer and would love to start mixing some tunes as soon as possible. Im having a problem though with distorted sound on the one channel and cant fix it, im sure its a simple solution and any advice would be greatly appreciated.
The setup is:
inputs: none
outputs: external mixer
sound card- 2 cards
sound card- realtek hi def
second card-audio usb
output channel- first/right
Im connecting the mixer with the right cables, the channels are split fine. The sound on the one channel is perfect but on the channel coming in through the sound card the sound is all fuzzy and distorted.
Can anyone help me?
Thank-you so much
cheers
The setup is:
inputs: none
sound card- 2 cards
Can anyone help me?
Thank-you so much
cheers
geposted Mon 01 Jun 09 @ 2:24 pm
