There seems to be a problem with the new 6.0 video decoder.
In .vob files with 5.1 ac3 audio, the audio is not recognized. VDJ just shows a line and there is no audio output but the video is playing.
However .vob with 2 channel ac3 is working correctly.
With version 5.2.1 also the 5.1 ac3 is playing.
If I change in the codec section of VDJ that .vob files should be decoded with Windows media player, the same .vob with 5.1 ac3 is playing. If I switch back to the internal video decoder of VDJ I no longer have audio.
This test shows that the problem is related to VDJ's video decoder. I never had this problem with VDJ 5.2.1.
Bug???
Bug???
geposted Mon 01 Jun 09 @ 8:00 pm
Right click on the video in the browser and select "File Infos"
Can you tell us the data written in File properties under "Filepath".
geposted Mon 01 Jun 09 @ 8:12 pm
I have the same problem it's an mpeg2 file with ac3 audio . VDJ 6.0 seems to be unable to decode the sound portion. I may have many files like this. I have no way to detect them.
Any help would be appreciated.
Here's my system:
Motherboard Asus Maximus Formula II
Quad Core Xeon X3230
Soundcard : MAudio Delta 1010LT
Graphic Card : Nvidia Quadro Fx 1700
8.00Go Ram
Windows Vista 64 Bit
C drive: 500Gb
D drive: 1500Gb
Here's my system:
8.00Go Ram
C drive: 500Gb
D drive: 1500Gb
geposted Mon 01 Jun 09 @ 11:19 pm
same question
geposted Tue 02 Jun 09 @ 1:44 pm
Info for 6 channel ac3 (audio part cannot be decoded)
FilePath=G:\video\something.vob
FileSize=188346369
File will be read with Video decoder.
VIDEO: mpeg2video, 720x576
AUDIO: ac3, 437 kbps, 48000 Hz, multi-chan
Info for 2 channel ac3 (audio is decoded and playing)
FilePath=G:\video\heaven.vob
FileSize=209500160
AUDIO: ac3, 437 kbps, 48000 Hz, stereo
FileSize=188346369
FileSize=209500160
geposted Tue 02 Jun 09 @ 8:10 pm
Go to config-> codec tab,
in the list you see vob video decoder
double click, then change decoder to windows media video decoder
this will work, but the speed of loading a .vob file is much slower.
geposted Tue 16 Jun 09 @ 4:45 pm
My problem it's the same and after install a codec package for windows media I don't obtain any other result. The same error continues.
geposted Fri 19 Jun 09 @ 6:33 am
Having the same problem - switching codec to Windows Media Player does not work - says "impossible to open file". What changed from version 5.2 to 6.0 with this???
geposted Wed 08 Jul 09 @ 2:45 pm
