Hi All,
Whenever I Launch VDJ, my screen resolution keeps Changing to a nightmarish on the eyes 60hz...
this happens at all resolutions...
And Only with VDJ..
Any Suggestions??
Thanks
netBeatz
And Only with VDJ..
Any Suggestions??
Thanks
netBeatz
geposted Wed 23 Mar 05 @ 9:17 pm
First of all...
What version of VDJ are you running and list your computer specs for us.
MS
MS
geposted Wed 23 Mar 05 @ 9:29 pm
Which skin are you using?
What resolution is your screen?
Are you using a skin that is the same as your resolution?
To answer you question of 'What is happening?'
When you launch VDJ the software will adjust your resolution to the width x height of the skin so that the application is using the entire screen. If the screen has a Maximize button click on it and the screen will go back to your original resolution. And the skin should be able to float in that resolution. If you shutdown VDJ, and reopen it you SHOULD NOT have to go through this exercise - unless you change skins; sometimes.
hope this helps.
cstoll
hope this helps.
cstoll
geposted Wed 23 Mar 05 @ 9:35 pm
Hi,
Running Ver. 2.01
Specs:
P4 2.66ghz
1GB RAM
Radeon 9700Pro
Windows XP Home
50GB Hard drive
Soundmax SoundCard
Sounblaster SoundCard
Running Ver. 2.01
Specs:
P4 2.66ghz
1GB RAM
Radeon 9700Pro
Windows XP Home
50GB Hard drive
Soundmax SoundCard
geposted Wed 23 Mar 05 @ 9:36 pm
2.01 is a very outdated version. (no longer supported) You should get the latest trial version. Then maybe your problems will clear up.
geposted Wed 23 Mar 05 @ 9:37 pm
Sorted...
Ran VDJ...Clicked Maximise...and Bingo
Refresh Perfect!!!!
Thanks All!!
Netz
Refresh Perfect!!!!
Thanks All!!
Netz
geposted Wed 23 Mar 05 @ 9:38 pm
It's like walking into a store, after you shoplifted a DVD player, and ask for instructions on how it works. Once you get those instructions you smile and say thanks...
I give up...
MS
I give up...
MS
geposted Wed 23 Mar 05 @ 9:56 pm
I cant beleive that just happened ................wtf is going on ....lol.
Dont give up Madd well get the next one
Andre
Andre
geposted Thu 24 Mar 05 @ 11:35 pm
