Well... The EQ crossfaders don't work anymore. They behave quite strange, can't really describe how exactly, but it doesn't really crossfade anymore. Any fix on this?
geposted Tue 02 Jun 09 @ 11:24 am
are you talking about mouse movement or by your midi controller?
geposted Tue 02 Jun 09 @ 2:15 pm
Simply on the skin, controlled with mouse. :)
geposted Tue 02 Jun 09 @ 2:29 pm
Yes, it's true.
I have problem with "bassfader".
Replacing "bassfader" with "eq_crossfader_low" I have the same problem.
Dev Team has to fix it.
geposted Tue 02 Jun 09 @ 4:04 pm
I'm hoping there's just an easy fix for this =)
geposted Wed 03 Jun 09 @ 9:10 am
Did you try Cel's new registry tool yet Van? I seem to remember something about setting EQ actions in it.
geposted Wed 03 Jun 09 @ 9:25 am
it doesn't fix that problem.
the registry tool can change the "EqInHeadphone" but now in the versione 6.0 it can be changed by VDJ options as well.
I already told Moramax about this issue and I think he is taking care about that.
geposted Wed 03 Jun 09 @ 11:21 am
The problem seems to have been fixed.
geposted Mon 08 Jun 09 @ 1:47 pm
What? It didn't :P
geposted Tue 09 Jun 09 @ 2:10 am
Yes, you are right.
I have noted this problem appers when I load both songs in the deck with BASSFADER.
Try to move all three crossfaders with 2 loaded songs and one song stopped (it seems the bassfader and the midfader are linked with each other).
Please, check this out!!!
geposted Tue 09 Jun 09 @ 4:50 pm
If i load in 1 song on one deck and leave the other one empty, everything works fine, everything fades as it should.
When i load in a second song, the mid & high seem to be working fine, but the bassfader only fades the bass of the song i've loaded second. It has no impact on the first song anymore.
geposted Wed 10 Jun 09 @ 2:28 am
I uphold the same thing.
geposted Wed 10 Jun 09 @ 3:44 am
[Sorry for my english skills]
Does VDJscript allow us to re-code ourselves a low crossfader ? For example, we know even how to :
- determine the side for the decks (action_deck 1 or 2)
- change the value of both low faders in the same action (ex: deck 1 eq_low +1 & deck 2 eq_low -1)
- toggle a global var in order to change the way of the low crossfader
Unfortunately, VDJscript does not allow us to create a slider/fader without a right source for its action parameter...
geposted Wed 15 Jul 09 @ 1:32 am
@deedstacktyk:
Everything is clear except "VDJscript does not allow us to create a slider/fader without a right source for its action parameter"
You can write it in french and I will translate it if you prefer.
geposted Wed 15 Jul 09 @ 6:17 am
Ok en français alors : je voulais dire qu'avec le VDJscript on ne peut pas utiliser un bouton rotatif ou un fader sans relier une des sources proposées par le moteur de VDJ6, exemple de sources : cpu, rotation, level_right, etc.
Sinon, le support staff m'a indiqué ça :
param_smaller 50% ? deck 2 eq_low : nothing & param_invert & param_smaller 50% ? deck 1 eq_low : nothing
à mettre dans le champ action d'un bouton rotatif ou d'un fader.
geposted Thu 16 Jul 09 @ 1:54 am
That will work for a midi controller, but I don't think it will work in skins.
Skin faders always need to take the value of something, you are right.
geposted Fri 17 Jul 09 @ 5:49 am
