On the playlist, how do you use Auto Mixing and force NO beatmixing? I would like it to be like a jukebox. Just play one song after another that I put in to the playlist.
Thanks.
Thanks.
geposted Thu 24 Mar 05 @ 12:32 am
Hi, In the FAME parameter:
- Disable the "Automatic BPM" and "Pitch-Reset"
- Enable the "force fade"
- Set the time to fade
Voila
Coyote
Voila
Coyote
geposted Thu 24 Mar 05 @ 1:45 am
Just a detail very important, "none" for the length (time) of fade doesn't work well. It's a bug in current version. The songs in the playlist are not loaded when "none". So use "1s" for the moment.
geposted Thu 24 Mar 05 @ 2:05 am
Thanks-
Force fade enable is what I was missing.
geposted Thu 24 Mar 05 @ 5:56 am
this bug might be fixed in next version ;)
geposted Thu 24 Mar 05 @ 8:15 pm
One more question-
What if I don't want the cue points that are auto inserted? I wish to play the whole song. Like a jukebox...
Thanks.
Thanks.
geposted Fri 25 Mar 05 @ 4:56 am
Well in fact you can do that with "none" but as you know
geposted Fri 25 Mar 05 @ 4:59 am
