Hi everyone,
I'm having a bit of a problem with the pitch/tempo reset (i.e. the 'Ctrl' + '*') function in VDJ6. If I start a song that is not at its normal tempo and then use that key combination to reset its tempo, I hear artifacts in the music until the tempo is reset. This only occurs when the keylock is engaged.
Initially I thought that it was some sort of soundcard performance issue, but what's strange is that if I move the pitch slider -- even to move it in order to reset its pitch -- there are no artifacts.
Could this still be a soundcard issue?
geposted Wed 03 Jun 09 @ 12:40 pm
It could be your Performance settings to high for your soundcard's ability. What are your Performance tab settings and what card are you using?
geposted Wed 03 Jun 09 @ 12:44 pm
Thanks for the response, Cstoll... I'm using the soundcard in my RMX and I've narrowed the problem down to my ASIO buffer size. I don't have a 5.2.1 install handy right now to do a direct comparison, but with 6.0, my buffer size has to be in the 20+ ms range to prevent the artifacts, whereas with previous versions, I've been able to use sub-10 ms buffer sizes, as low as 2ms or 4ms.
It's not a huge deal as I don't do a lot of fast scratching at all, but if there is a solution to this, I'd love to hear it.
I'm running it on Windows 7 64-bit.
Oh, and I'm also running the latest RMX drivers, so that can't be the issue.
geposted Wed 03 Jun 09 @ 3:07 pm
This does not happen on 5.x
Does not happen if Keylock is turned off.
As much as I love master tempo and VDJ, VDJ's implementation leaves much to be desired.
geposted Mon 20 Jul 09 @ 9:32 am
With 6.0 and using tc engine v5 with cd's i have to raise my buffer 5x higher @ 512 (12ms) to prevent pops when I move the platter slow back and forth, specially when scratching. On 5.2 with tc engine v4 I was running my buffer @ 128 (2 ms) with no problems at all.
Vdj please bring back tc engine v4 on next update.....
geposted Mon 20 Jul 09 @ 10:10 am
