Hello another dumb question but not really. I am trying cut pieces from some other mixes that are like 25 minutes long but when you load a song that load virtual dj does not show the entire wave above the track thought VDJ 6 might fix this but it still does it
geposted Wed 03 Jun 09 @ 5:58 pm
lol, me again.
make sure you have MAX LOAD set to always and this should solve your problem.
CONFIG--->OPTIONS
CONFIG--->OPTIONS
geposted Wed 03 Jun 09 @ 6:00 pm
It used to be common with files with 30 minutes more, like complete shows. The files dont load, but playback were fine.
Yesterday, even with the max load set up, the problem was happening with 5 minutes (only) files... then I reset VirtualDJ and the issue becomes to the first stage.
geposted Wed 03 Jun 09 @ 6:54 pm
