Got my music in 3 folders one folder is displaying the wrong number of files showing 92 files when I know there are 111 files, ive double checked, there are 111 mp3 files!
Can anyone help me.....thanks
geposted Fri 25 Mar 05 @ 12:52 pm
Did you check if you have some hidden files ?
geposted Fri 25 Mar 05 @ 8:22 pm
Thankz that was the problem , files been played by media player which created hidden album art files.
VDJ Rulz!
VDJ Rulz!
geposted Fri 25 Mar 05 @ 10:10 pm
i am missing files , how do you no if the files are hidden or if a other player has them into a playlist i hope some one can help me thanks.
geposted Sat 26 Mar 05 @ 10:57 pm
I'll try to help you (english is not my first language and my PC is configured in french).
Go into Windows Explorer (workstation) then select the tools menu then click on folders options.
There you go to the display menu and select display hidden files.
After that do a search to find your files.
geposted Mon 28 Mar 05 @ 9:45 am
Great nitebeatdisco
Happy to see your problem is solved.
geposted Mon 28 Mar 05 @ 9:46 am
