Hi
I'm just in the process of mapping my xp10s in vdj6 new mapping script.
I've pretty much cracked it, what I would like to know is....
I've already set one shift variable for each button but is it possible to set a second shift or even a third like in the old mapper?
If so, what would the script look like?
Thanks
PJay
Thanks
PJay
geposted Thu 04 Jun 09 @ 9:52 am
PJay wrote :
Hi
Thanks
PJay
Thanks
PJay
Why are you mapping it ... or are you 'remapping' the default mapper that is natively there ?
What are you looking to accomplish with these shifts? Give me an example and maybe through that I can help.
geposted Thu 04 Jun 09 @ 10:10 am
Hi
thanks for the quick response.
i was just remapping the default mapper so i could have it set up same as vdj5, the default button settings are nothing like the buttons on the xp10s (vdj version).
anyway i got most of it working but on the old version i had for example
Cue 1 = Hot_cue 1
Shift 1 + Cue 1 = Delete cue 1
Shift 2 + Cue 1 = Rename cue 1
but in vdj 6, ive only set 1 shift variable eg
var 'shift' ? delete_cue 1 : hot_cue 1
is there anyway to add another shift option so i can add a third function to the button?
Thanks
PJay
Cue 1 = Hot_cue 1
Thanks
PJay
geposted Thu 04 Jun 09 @ 10:32 am
Ok, first do you have a button assigned to do the 'shift' ? And if so what statement did you use?
And yes you could add another shift to another button but then that would mean you would have to press 3 buttons to make 1 action ..
geposted Thu 04 Jun 09 @ 10:38 am
ok, ive got this so far
set 'shift' 1 temporary
so cue on its own is hot_cue 1
and when i press shift and cue , it deletes it, which all works fine
what im wanting is to set another button eg 'shift 2' so that when i press shift 2 and cue, it does another function like in vdj 5
is it possible?
PJay
is it possible?
PJay
geposted Thu 04 Jun 09 @ 11:07 am
Ok so no problem .. I know you may understand what the -> [condition] ? [true] : [false] is doing so it quiet simple ...
First ... would recommend changing what you have ( while_pressed , is preferred instead of temporary) -
Shift 1 button -> set "shift1" 1 while_pressed
Then set a second button to -> set "shift2" 1 while_pressed
Now the CUE button -> var_equal "shift1" 1 ? delete_cue 1 : var_equal "shift2" ? rename_cue 1 : hot_cue 1
So in words the CUE button does this when pushed...
If button Shift1 is pressed (variable Shift1 is 1 OR [true]) then delete cue point 1,
If button Shift1 is not pressed (variable Shift1 is not set to 1 OR [false]) then check,
If button Shift2 is pressed (variable Shift2 is 1 OR [true]) then rename_cue 1,
If button Shift2 is not pressed (variable Shift2 is not set to 1 OR [false]) then activate the HOT CUE 1 point.
Did I go over the top ?
Chris
Chris
geposted Thu 04 Jun 09 @ 11:55 am
Thankyou,
for some reason i actually understood that, ill update the mapper soon
thanks for the answer
PJay
PJay
geposted Thu 04 Jun 09 @ 12:14 pm
Chris
Chris
right took a while to get the 3rd function working, finally figured out why it wasnt working....
i used your script "var_equal "shift1" 1 ? delete_cue 1 : var_equal "shift2" ? rename_cue 1 : hot_cue 1"
the cue rename didnt work untill i figured out that its supposed to be cue_name instead of rename_cue lol, also it took a "1" after the "shift2" peram
so now ive got....
var_equal "shift1" 1 ? delete_cue 1 : var_equal "shift2" 1 ? cue_name 1 : hot_cue 1
that works fine apart from the cue_name function opens between 3 and 8 popup windows for the cue name
any ideas?
PJay
geposted Thu 04 Jun 09 @ 12:56 pm
never mind, i just restarted the xp10 and vdj and its fine now
Thanks for your help
PJay
PJay
geposted Thu 04 Jun 09 @ 1:05 pm
Sorry about the 'script' flop ... been writing a few of these lately ... :)
geposted Thu 04 Jun 09 @ 1:48 pm
thats ok, keeps me on my toes and helps me understand it more than just plain copying it :)
geposted Thu 04 Jun 09 @ 1:50 pm
