Can you guys give me an example on how I can assign a button when pressed will change the different optional mode and be able to scroll thru them by assigning the scroll button to do so.
I also want to be able to assign different buttons for effects and use the scroll button to use the different parameters in those effects!
geposted Thu 04 Jun 09 @ 12:21 pm
Give me an example of what encoders or buttons you want to use and just 1 ability you want to perform ... then we can work from there ...
geposted Thu 04 Jun 09 @ 1:35 pm
I want FX2 button to deck effect active at the same time to trigger the scroll button to be able to be able to increase and decrease the different effects parameters, also i want the the FX2 button to be able to be able to go thru the different parameters
effects. I want to be able to see them on the DN-S1200!
ex: Fx2 button= effect activate & navigate thru effect' s parameters & activate scroll button to work with effect parameters to increase and decrease.
I hope u can understand that lol!
geposted Thu 04 Jun 09 @ 4:34 pm
