Hi im been looking around for a skin what will use 2 monitors, 1 monitor will have decks and so on the other play list and library.
Is there skin like this about, if not is there anyway to edit a skin myself ive never done it before but wouldn't mind giving it a go.
geposted Thu 04 Jun 09 @ 2:33 pm
Hi,
I think this is the only skin now available that was made for two screens:
https://virtualdj.com/addons/5797/Multi_functions_2_screens.html
If you want to edit a skin, or create a new skin using an existing one,
you will need to work a bit on the graphics first.
And then you can use the Skin Creator Tool:
https://virtualdj.com/addons/5990/VDJ_Skin_Creator_Tool.html
to edit the code part (XML file).
I think all you will need to do is edit the "Browser" element position and size, in order to display it on the second screen.
geposted Thu 04 Jun 09 @ 3:10 pm
