Hi i am not sure if i have a setting wrong it just that i can not get the bpm excact on both turntables i am using the RMX even when using the pitch controls i am either 123.01 on one side or 123.03 on the other if i sync its the same it seems to drop by .02 all the time i did not have this problem before updating.Have i set someting wrong, advice would be most welcome.
geposted Thu 04 Jun 09 @ 3:26 pm
What you are seeing is the rounding difference .. and since you are seeing 2 decimals in the new skins you are actually seeing it. In v5 majority of skins only showed 1 decimal. I know it looks weird .. but they are correct and 0.02 is the common difference 'VISUALLY'
geposted Thu 04 Jun 09 @ 6:29 pm
Thanks very much for your reply all is now clear.
geposted Fri 05 Jun 09 @ 2:15 am
