Does any know whether or not you can record video in VDJ6 running Vista? It still seems to be a codec problem that hasn't been fixed. I can get the older version to work in xp but I want to run it on my Vista machine.
geposted Thu 04 Jun 09 @ 3:33 pm
And it's been posted several times on the forums that you need to download the MPEG Codec from Microsoft and install it.
http://www.windows-vista-update.com/Windows_Vista_codecs.html
geposted Thu 04 Jun 09 @ 6:34 pm
I'll try it, thanks!
geposted Fri 05 Jun 09 @ 11:24 am
I've tried the download and I'm still getting a Video codec not found error. Any help? I must be missing something.
geposted Fri 05 Jun 09 @ 12:04 pm
hey nsxmarv try downloading from this site
http://www.movavi.com/codec/mpg4.html
download the mpeg4x codec,that should do it. After that go to config>codecs and add mpg4 codec and the appropriate decoder and that should do it.
geposted Sat 06 Jun 09 @ 2:32 am
Thanks you guys, it's working now. Now I can get version 6 with no worries.
geposted Sun 07 Jun 09 @ 7:01 pm
Does it work for version 5.21 as well because it frustrating the shit out of me
geposted Wed 10 Jun 09 @ 7:31 am
Yeah I did get it to work on 5.2.1. It is frustrating but sooner or later it does work. Where I had the most problem was with the codecs section of config. I finally found the right codec (mpg4) and it worked.
geposted Mon 15 Jun 09 @ 3:14 pm
Yeah, where do u find the codec for mpg4? I'm having trouble. I have windows media player 11, and am running the newest version (6) of VDJ. Can someone that has it working please post some screenshots of there settings?
geposted Sun 21 Jun 09 @ 8:01 am
I'm trying this download, and will let you know if it works. I'm running XP btw.
geposted Sun 21 Jun 09 @ 8:03 am
In 5.2 go to the record section, then record movie, then config, then under the format section where it says codec, type in mpg4. That should work.
geposted Mon 22 Jun 09 @ 4:38 pm
I forgot in my last post to tell you to download the codec first.
geposted Mon 22 Jun 09 @ 4:39 pm
i install everything still dont work.. how do i fix it on the configuration of virtual dj ..
geposted Mon 20 Jul 09 @ 2:49 am
yes can some one who has this post screen shots... help the others ( mee )
geposted Mon 20 Jul 09 @ 2:58 am
same here, i've installed the vista codec package and set the configuration to mpg4 to record video and still continue to get the VIDEO CODEC NOT FOUND.
geposted Wed 22 Jul 09 @ 3:19 pm
any helppppppppppp
any helppppppppppp
geposted Fri 24 Jul 09 @ 8:05 pm
I'll try to list step by step what I did to get it to work. I'm not the computer genius like some of the guys here, but I'll try my best. I'll undo what I did and start the process over. Give me a couple of days so I can post it.
geposted Tue 28 Jul 09 @ 4:28 pm
okay, im a little confused on this codec thing. When we install codec packs, like K-Lite or this Vista Codec pack, i assume these are just codec for playback? or do they also pertain to recording codec...or is that a different install all together?
geposted Wed 29 Jul 09 @ 1:23 am
Did you download the codec that oqed posted?
geposted Wed 29 Jul 09 @ 10:32 am
i've installed both codec and followed the steps and still no luck.
"http://www.windows-vista-update.com/Windows_Vista_codecs.html"
"http://www.movavi.com/codec/mpg4.html"
choosing mpg4 in video codec option "video decoder"
geposted Wed 29 Jul 09 @ 1:52 pm
