I cannot find the section in config where you select the controller-i am using numark total control, but there is no where to select the controller like in version 5. how do i get it to work
geposted Thu 04 Jun 09 @ 7:21 pm
how do i get the controller to work in version 6
geposted Thu 04 Jun 09 @ 7:22 pm
Working just fine here. Plug it in the usb port and connect the power - start computer - start VDJ6.0.1 - And there you go.
Have another problem with v6: My virtual folders is gone. Could anybody help?
geposted Thu 04 Jun 09 @ 8:10 pm
Controllers are automatically recognised - no longer manually activated. Have a look on the Mappers tab and click the button next to the dropdown box.
You could alse try reading the user guide on the start menu which details all these sort of things ;)
geposted Fri 05 Jun 09 @ 7:32 am
You already have a thread on this; no need to hijack others :)
geposted Fri 05 Jun 09 @ 7:33 am
With version 6.0.1 My DAC 2 controller shows on the mapping tab but wont map automatically. To map it manually there are to many variables that I don't know which one to choose. Has anyone seen this problem? It worked on earlier versions just fine.
geposted Sun 07 Jun 09 @ 1:21 pm
