I'm getting green flashes in my video playback with VDJ6. Works great in 5.2 so not sure what is happening. It happens in every single video.
Without going into a full blown list of specs, suffice to say it is a powerful machine with even more power than the 'suggested' setup.
geposted Fri 05 Jun 09 @ 2:15 am
Well we need full blown specs to help ya. XP or Vista?? Vid Card??? And everything else you can list. I had this issue with a vid card made for DX10 on my XP system (ATI HD 4850). So more info is needed.
geposted Fri 05 Jun 09 @ 4:48 am
Not only that, the display is like washed out. Uncheck the hardware acceleration and it goes away. Video card is on board, BTW.
geposted Fri 05 Jun 09 @ 9:22 am
OK, if you insist.
Vista 32
Intel Quad Core
4GB High Speed Low Latency RAM
NVIDIA 8800GTX Video w/ 750MB DDR3 RAM
7200 1TB Hard Drive with 32MB Cache
Divx encoded video at 1500Kbps
Always worked great in 5.2
I will try disabling hardware acceleration as the previous poster suggested.
Vista 32
Intel Quad Core
geposted Fri 05 Jun 09 @ 3:24 pm
