Just downloaded VDJ6......
I asked this question before for VDJ5
but i see 6 has a different interface....
Im using time code and need to cross fade JUST the video via keyboard keys...
Can someone supply step by step instructions on how to do this in 6?
Thanks!
Thanks!
geposted Fri 05 Jun 09 @ 7:41 am
How would you like the crossfade to work 'cut' or how fast of a transition ? And which keyboard keys do you want to use?
geposted Fri 05 Jun 09 @ 8:01 am
I just want it to do a smooth transition...The keyboard keys doesn't matter.
geposted Fri 05 Jun 09 @ 1:44 pm
Assign 1 keyboard key or key+combo to -> video_transition 5000ms <- this will give you a 5 sec transition from the current deck to new deck. And adjust the 5000 value up or down if you thing it's to slow or fast.
geposted Fri 05 Jun 09 @ 1:52 pm
Can you give me STEP BY STEP instructions on doing this........I just tried doing it and it didn't work.......
Thanks
Thanks
geposted Sat 06 Jun 09 @ 9:18 am
Ok, using timecode I guess the ARROW keys could be cool to use for the video crossfade
(by the way, you CAN link the video crossfader to audio crossfader in video options + add the auto feature,and let the software do cool video transitions while you audio crossfade)
Anyways, go to MAPPER tab in VDJ options
At the keyboard mapper, find the entry "RIGHT", and click it to select it
1) In the action field to the right, write this : video_crossfader +1
2) press "OK" at the bottom of the window
Then for ARROW LEFT key to the same again, to to MAPPER tap
At the keyboard mapper, find the entry "LEFT", and click it to select it
1) In the action field to the right, write this : video_crossfader -1
geposted Sat 06 Jun 09 @ 9:35 am
Or you can map "one click auto transiton"
To the same, go to MAPPER
At the very bottom of the list, for keyboards there is a "NEW"
Choose this one.
At the right side :
At the "KEY" field , press the key A (for auto transition, or choose other key)
At the "ACTION" field write : video_transition 5000ms
Voila;)
Choose this one.
At the right side :
Voila;)
geposted Sat 06 Jun 09 @ 9:41 am
Simply amazing..:) It's very different from 5. THANKS FOR THE STEP BY STEP! Works GREAT!!! Nice and smooth 1 button transition for my time code video setup :) Thanks norway
geposted Sat 06 Jun 09 @ 11:02 am
Just glad to help ;)
geposted Sat 06 Jun 09 @ 11:17 am
Good Karma for you buddy :-)
geposted Sat 06 Jun 09 @ 11:27 am
