i was just wondering if i can get a link to get ver.5.2.1 back. i installed 6.0. witch i do like but im using a xponent and i cant get it to work with 6.0. i have a gig tonight and i need it to work. it works just fine with the older version. thanks
geposted Fri 05 Jun 09 @ 10:33 am
You should have kept the install file ;)
You will have to contact support to get the older version back; an install file from someone else won't work.
geposted Fri 05 Jun 09 @ 10:43 am
yea i should have. i thought i had it but i cant find it :(. anyone got it the install file and would like to send it to me or post it?
geposted Fri 05 Jun 09 @ 11:42 am
damn i didnt know that. all it says is 6.0.1 and thats it
geposted Fri 05 Jun 09 @ 11:56 am
THANKS A BUNCH!!!
geposted Fri 05 Jun 09 @ 2:09 pm
