Hey guys, just downloaded the new version and I am having some issues. When I load a song on a deck it will not load completely. Never had any issues like this before. I've checked all the settings to make sure it is exactly how I had it in 5.2.1 when I wasn't having any problems. Any one have any idea what could be causing this or how I can fix it?
geposted Fri 05 Jun 09 @ 3:03 pm
what do you mean . we maybe have same problem but my songs doesn load witt bass . bass is very low :S sry for my english , Peace
geposted Fri 05 Jun 09 @ 4:59 pm
Try going to the config tab and under options and be "Max Load Always" is selected
~R~
~R~
geposted Fri 05 Jun 09 @ 5:06 pm
Thanks for the input! I think I may have solved the issue...seems to be working better now that I dled the latest Direct X.
geposted Fri 05 Jun 09 @ 5:56 pm
