I'm trying to figure out the script to scroll my sound effects, video effects and video transitions using "Browser_scroll" but I can't seem to get the right verbiage.
Can someone help me out?
Thanks
Thanks
geposted Fri 05 Jun 09 @ 10:30 pm
Browser_scroll is for scrolling through the 'songs' or the 'folders'
What exactly are you trying to do ... can you be more specific?
geposted Sat 06 Jun 09 @ 1:19 am
I'm trying to mimic JPBoggis's mapper when I'm in "Sound Effects" mode by using the circular button on the Denon hc 4500 to scroll down the sound effects page and play the effects by pusing the button. I want to perform the same action for video effects and video transitions.
geposted Sat 06 Jun 09 @ 5:10 am
I don't know the new VDJScript command, but the "effect_select_multi +1" / "effect_select_multi -1" 5.x command is what you're looking for! ;)
geposted Sat 06 Jun 09 @ 2:17 pm
I can't figure it out.
I wish there was a command like "browser Scroll" for the sound effects, video effects and video transitions. that would make things so much simpler.
geposted Sat 06 Jun 09 @ 5:23 pm
First you would need to map a button to select mode, e.g:
TITLE =
Then assign actions for turning the parameter knob:
TRACK_KNOB =
TRACK_KNOB_DOWN =
TITLE =
cycle 'mode' 4 & var_equal 'mode' 1 ? show_text "Effects|Mode" : var_equal 'mode' 2 ? show_text "Video|Mode" : var_equal 'mode' 3 ? show_text "Sampler|Mode" : show_text "Normal|Mode"
TRACK_KNOB =
var_equal 'mode' 1 ? effect select : var_equal 'mode' 2 ? video_fx_select : var_equal 'mode' 3 ? sampler select : browser_scroll
TRACK_KNOB_DOWN =
var 'fx_mode' 1 ? effect active : var_equal 'mode' 2 ? video_fx : var_equal 'mode' 3 ? sampler play_stop : browser_enter
geposted Sat 06 Jun 09 @ 6:03 pm
Thank YOU!
By the way, what is the command for YOUR loop mode where you can change the loop with the knob control?
geposted Sat 06 Jun 09 @ 9:12 pm
I figured it out. thanks everyone for your support especially JPBoggis.
geposted Sat 06 Jun 09 @ 10:02 pm
