Hi, tried out the trial of vdj last night, only problem I had was with some videos it would add extra music to the end of it, the video would end where it would normally have a second of silence and replay the last few bars and not show the video of it. You can see the extra sound in the waveform.
geposted Sat 06 Jun 09 @ 4:18 am
Were you using the master tempo on the deck when it appeared?
geposted Sat 06 Jun 09 @ 5:28 am
Can't remember, I don't think so, don't usually use master tempo unless needed, I did have it on at one point, I'll see tonight, it did it with a few vids, not all.
geposted Sat 06 Jun 09 @ 5:30 am
@djfs
I think you have a problem on your computer as you always posts twice on this forum (i had to remove duplicates)
geposted Sat 06 Jun 09 @ 5:38 am
Thanks, yeah I don't know why its doing that, I'm on my BlackBerry, it must be cause of that, dunno why.
P.S. Delete the 2nd post if it appears. Sorry.
geposted Sat 06 Jun 09 @ 5:40 am
Ok tonight, mt turned off or on, same problem.
Thought it might be the way the dvd was ripped, but other vobs off the same disc work.
This is only the trial, dunno if its the same in 6.0.1
Still waiting for the cue version, so I'll go back to the old cue, its annoying when ya forget and the fader is still up! Lol.
geposted Sat 06 Jun 09 @ 9:36 pm
any more update with this? is this a 6.0 problem and fixed in 6.0.1?
geposted Tue 09 Jun 09 @ 10:21 am
If you are seeing the track in the wave form continue, there is data in that rip being read.
What is the video source, PO SP RA ETV?
And why has nobody else got this problem?
geposted Tue 09 Jun 09 @ 11:06 am
Dvd is from videopool and I also have a retail proclaimers dvd where it does it on the 500miles track
geposted Tue 09 Jun 09 @ 11:15 am
Still think its a bad rip, but door open to be wrong.
If you have Vegas, load it in there and see what it looks like.
Did you check this in other software that will handle vob like Power dvd?
geposted Tue 09 Jun 09 @ 11:26 am
I'll give it a try, works ok in 5.2.1, but I have vegas, I'll check tomorrow.
geposted Tue 09 Jun 09 @ 11:29 am
Ok, tied in in vegas and powerdvd, it played ok, tried it on another pc running vdj trial and it worked ok. Strange!
I clicked check, clean and fix on the one with the problem and reloaded the video and it worked ok after that.
geposted Wed 10 Jun 09 @ 3:36 pm
