ich brauche für VDJ 6 alle actions. Ich habe noch das alte Mapping und muss mir ja nun leider :( ein neues versuchen zu machen. Kann mir mal jemand die actions sagen wie die nun heißen ?
<?xml version=\"1.0\" encoding=\"windows-1252\"?>
<midi version=\"5\" date=\"11/01/2008\">
<note note=\"36\" action=\"cue_stop\" chan=\"1\" />
<note note=\"68\" action=\"cue_stop\" chan=\"2\" />
<note note=\"21\" action=\"play\" chan=\"1\" />
<note note=\"53\" action=\"play\" chan=\"2\" />
<note note=\"18\" action=\"sync\" chan=\"1\" />
<note note=\"50\" action=\"sync\" chan=\"2\" />
<note note=\"20\" action=\"loop\" chan=\"1\" />
<note note=\"55\" action=\"loop\" chan=\"2\" />
<note note=\"34\" action=\"effect_activate\" chan=\"1\" />
<note note=\"70\" action=\"effect_activate\" chan=\"2\" />
<ctrl ctrl=\"36\" mode=\"encoder\" encodermode=\"0\" action=\"browser_updown\" increments=\"1\" />
<ctrl ctrl=\"44\" mode=\"encoder\" encodermode=\"0\" action=\"browser_updown\" increments=\"1\" />
<note note=\"24\" action=\"browser_open\" chan=\"1\" />
<note note=\"56\" action=\"browser_open\" chan=\"2\" />
<ctrl ctrl=\"37\" mode=\"encoder\" encodermode=\"0\" action=\"jogwheel\" chan=\"1\" increments=\"32\" />
<ctrl ctrl=\"45\" mode=\"encoder\" encodermode=\"0\" action=\"jogwheel\" chan=\"2\" increments=\"32\" />
<note note=\"37\" action=\"browser_switch\" value=\"1\" />
<note note=\"69\" action=\"browser_switch\" value=\"1\" />
<note note=\"22\" action=\"browser_switch\" value=\"2\" />
<note note=\"54\" action=\"browser_switch\" value=\"2\" />
<note note=\"11\" action=\"play\" chan=\"1\" />
<note note=\"43\" action=\"play\" chan=\"2\" />
<ctrl ctrl=\"35\" mode=\"encoder\" encodermode=\"0\" action=\"gain\" chan=\"1\" increments=\"8\" />
<ctrl ctrl=\"40\" mode=\"encoder\" encodermode=\"0\" action=\"gain\" chan=\"2\" increments=\"8\" />
<ctrl ctrl=\"34\" mode=\"encoder\" encodermode=\"0\" action=\"pitch\" chan=\"1\" increments=\"1\" />
<ctrl ctrl=\"41\" mode=\"encoder\" encodermode=\"0\" action=\"pitch\" chan=\"2\" increments=\"1\" />
<ctrl ctrl=\"33\" mode=\"slider\" action=\"loop\" chan=\"1\" scale=\"0\" />
<ctrl ctrl=\"19\" mode=\"slider\" action=\"sample_volume_1\" scale=\"0\" />
<ctrl ctrl=\"18\" mode=\"slider\" action=\"sample_volume_2\" scale=\"0\" />
<ctrl ctrl=\"17\" mode=\"slider\" action=\"sample_volume_3\" scale=\"0\" />
<ctrl ctrl=\"16\" mode=\"slider\" action=\"sample_volume_4\" scale=\"0\" />
<ctrl ctrl=\"31\" mode=\"slider\" action=\"sample_volume_5\" scale=\"0\" />
<ctrl ctrl=\"30\" mode=\"slider\" action=\"sample_volume_6\" scale=\"0\" />
<ctrl ctrl=\"29\" mode=\"slider\" action=\"sample_volume_7\" scale=\"0\" />
<ctrl ctrl=\"28\" mode=\"slider\" action=\"sample_volume_8\" scale=\"0\" />
<note note=\"29\" action=\"sample_play\" value=\"1\" />
<note note=\"15\" action=\"sample_play\" value=\"2\" />
<note note=\"17\" action=\"sample_play\" value=\"3\" />
<note note=\"27\" action=\"sample_play\" value=\"4\" />
<note note=\"61\" action=\"sample_play\" value=\"5\" />
<note note=\"47\" action=\"sample_play\" value=\"6\" />
<note note=\"49\" action=\"sample_play\" value=\"7\" />
<note note=\"59\" action=\"sample_play\" value=\"8\" />
<note note=\"38\" action=\"master_tempo\" chan=\"1\" />
<note note=\"66\" action=\"master_tempo\" chan=\"2\" />
<note note=\"19\" action=\"menu\" value=\"-1\" />
<note note=\"33\" action=\"menu\" value=\"+1\" />
<note note=\"51\" action=\"menu\" value=\"-1\" />
<note note=\"65\" action=\"menu\" value=\"+1\" />
<note note=\"14\" action=\"sample_select\" />
<note note=\"28\" action=\"load_sample\" value=\"1\" />
<note note=\"14\" action=\"load_sample\" value=\"2\" />
<note note=\"16\" action=\"load_sample\" value=\"3\" />
<note note=\"26\" action=\"load_sample\" value=\"4\" />
<note note=\"60\" action=\"load_sample\" value=\"5\" />
<note note=\"46\" action=\"load_sample\" value=\"6\" />
<note note=\"48\" action=\"load_sample\" value=\"7\" />
<note note=\"58\" action=\"load_sample\" value=\"8\" />
<ctrl ctrl=\"33\" mode=\"encoder\" encodermode=\"0\" action=\"sample_select\" chan=\"1\" increments=\"1\" />
<ctrl ctrl=\"41\" mode=\"encoder\" encodermode=\"0\" action=\"sample_select\" chan=\"2\" increments=\"1\" />
<ctrl ctrl=\"32\" mode=\"encoder\" encodermode=\"0\" action=\"effect_select\" chan=\"1\" increments=\"1\" />
<ctrl ctrl=\"43\" mode=\"encoder\" encodermode=\"0\" action=\"effect_select\" chan=\"2\" increments=\"1\" />
<ctrl ctrl=\"9\" mode=\"slider\" action=\"effect_slider_1\" chan=\"1\" />
<ctrl ctrl=\"8\" mode=\"slider\" action=\"effect_slider_2\" chan=\"1\" />
<ctrl ctrl=\"11\" mode=\"slider\" action=\"effect_slider_3\" chan=\"1\" scale=\"0\" />
<ctrl ctrl=\"10\" mode=\"slider\" action=\"effect_slider_4\" chan=\"1\" scale=\"0\" />
<ctrl ctrl=\"13\" mode=\"slider\" action=\"effect_slider_5\" chan=\"1\" scale=\"0\" />
<ctrl ctrl=\"21\" mode=\"slider\" action=\"effect_slider_1\" chan=\"2\" scale=\"0\" />
<ctrl ctrl=\"20\" mode=\"slider\" action=\"effect_slider_2\" chan=\"2\" scale=\"0\" />
<ctrl ctrl=\"23\" mode=\"slider\" action=\"effect_slider_3\" chan=\"2\" scale=\"0\" />
<ctrl ctrl=\"22\" mode=\"slider\" action=\"effect_slider_4\" chan=\"2\" scale=\"0\" />
<ctrl ctrl=\"25\" mode=\"slider\" action=\"effect_slider_5\" chan=\"2\" scale=\"0\" />
</midi>
</midi>
geposted Sat 06 Jun 09 @ 9:56 am
Also die Actions kannst Du z.B. sehen wenn Du im Mapper in das Action Feld tippst. VDJ zeigt Dir dann alle Actions an die zu Deiner Eingabe passen. Wenn Du jetzt die Action in der Liste anklickst kannst Du die Hilfe dazu lesen.
Ansonsten findest Du alle Actions entweder hier: https://virtualdj.com/wiki/VDJscript_verbs.html in Englisch oder im Language File unter 'Eigene Dateien/Virtual DJ/Languages/German.xml'.
So riesig sind die Unterschiede aber gar nicht. Welchen Controller willst Du denn mappen ? Am besten schaust Du mal in ein bestehendes Mapping File mit dem Texteditor rein. Da findest Du schon einige Anwendungsmöglichkeiten oder Du schaust mal hier im VDJScript Wiki Eintrag nach: https://virtualdj.com/wiki/VDJscript%20-%20Virtual%20DJ%20Script%20f%C3%BCr%20VirtualDJ%206.x.html
geposted Sat 06 Jun 09 @ 10:06 am
jo muss ich dann mal reinschauen. nur geht das cnith so. wenn ich im ordner mapping ein file mit den namen Allen and Heath Xone 3D eintrage das er das in der liste mit anzeigt. Weil ich wollte dann eins machen das ich zum Download anbieten kann. Gibbet dazu noch ein Tut ? oder schreibt einer ein Mapping für das Xone 3D??
geposted Sat 06 Jun 09 @ 10:17 am
Also wenn der A&H noch nicht Nativ unterstützt wird musst Du zuerst ein sogenanntes Definition File erstellen. Dort wird jeder Taste ein selbstgewählter Name zugeordnet. Du machst sozusagen eine Zuordnung der Midi Note oder des Contol Changes auf einen Klartextnamen.
Diese Datei kommt unter Devices. Danach kannst Du eine (leere) Mapper Datei in den Mappers Ordner legen. Wenn das soweit alles geklappt hat wird Dir bei angeschlossenem Mischpult automastisch der Mapper im Pulldown Menu angezeigt.
Schau Dir mal folgendes etwas genauer an: https://virtualdj.com/wiki/German ganz am Ende findest Du eine Anleitung wie man MIDI Geräte definiert. Wenn Du da Probleme hast lass Dir einfach mal von Braenzu den VCI-100 Mapper + Definition von mir schicken. Da kannst Du Dir ein paar Sachen abschauen.
P.S. Würde gerne helfen, bin aber ab heute Abend erstmal für 2 Wochen in Urlaub ;-) Kannst Dich ja ab dem 22.06. nochmal bei mir melden.
geposted Sat 06 Jun 09 @ 10:36 am
soweit sollte nun alles passen nur kann ich mir das tausendmal durchlesen etc.. wie bekomme ich nun meine sysexid="WERT" raus. schon zich mal gelesen aber nichts kapiert :(
geposted Mon 08 Jun 09 @ 5:36 am
Kann mir einer den mapper für ION Discover Dj schicken ?
westcityboy05@yahoo.de
geposted Wed 27 Jan 10 @ 10:12 am
Den kannst Du (sofern Deine Lizenz das zulässt) hier herunterladen: https://virtualdj.com/addons/10329/ION_Discover_DJ_Def___Mapper.html
Ansonsten wird Dir wohl kaum jemand das File schicken. Außerdem, was willst Du damit ???
Der Mapper funktioniert mit Deiner Version nicht !
Du kannst nur den Controller verwenden mit dem die Software ausgeliefert wurde.
geposted Wed 27 Jan 10 @ 10:23 am
