ok, so in like 2 hours I am leaving for a wedding. I know I screwed this up but my mk2 isn't working with 6.0. I am stressed and am not thinking right. What do I need to do to fix this?
geposted Sat 06 Jun 09 @ 1:01 pm
enable it as controller in v6 mapping page
If you already did, what is not working right?
The jogs? Download the lastest 6.01 update
https://virtualdj.com/download/updates.html
geposted Sat 06 Jun 09 @ 1:07 pm
It doesn't play, load tracks, anything. All I did was dl 6.0. Do I need to redownload the dj console too?
geposted Sat 06 Jun 09 @ 1:14 pm
This is just a bit out there but when you hook up the MK2, before you load VDJ check MK2 start box for asio checked by mistake. I sometimes forget to change the setting if I use TC and it take a minute from my heart stop to realize the situation. OR - unplug you controller and plug it back in just in case the midi drivers did not load correctly.
geposted Sat 06 Jun 09 @ 6:37 pm
Well, it's a bit late for today, but you should download and install the latest driver package from Hercules (2009_HDJS_1 package) here.
geposted Sat 06 Jun 09 @ 6:52 pm
