Could one of you help me on this one:
How can I shortcut/link the F1 - F10 keys to the 10 Samples/Jingles that are available in Virtual DJ?
I checked the Keyboard Shortcut-tab in Configure however I am referred to this website for help.
Help/advice is appreciated!
Kind regards, Hydra
Kind regards, Hydra
geposted Sat 26 Mar 05 @ 2:09 pm
the program defaults the sample shortcuts to F1-F12, and Shift+F1-F12 for temporary Sample.
Go to settings, key board shortcuts. That will bring up a list of all of your shortcuts. If your samples are not listed then click add, samples, sample.. when the window pops up place the sample number in the value box, click momentarily if you want the sample to play only when you have the key pressed or leave it unchecked if you want the whole sample to play with one key press, then hit the key you want to assign this too, then press OK. Repeat the same steps for all of your samples. when your done save your shortcuts.
Paisan
Paisan
geposted Sat 26 Mar 05 @ 3:13 pm
If you don't have the default file, have a loook here:
https://virtualdj.com/forum/display.html?topic=10979
geposted Sat 26 Mar 05 @ 3:43 pm
I installed the default file. Works perfect!
Thanks,
Hydra
Thanks,
Hydra
geposted Sat 26 Mar 05 @ 8:55 pm
