Hello, i would like to ask cstoll for some assistance here. I know he made the mapper for the bcd3000. I have the problem that the led´s on the controller wont light up when pressed/ true. I dont understand the vdjscript fully. What will i have to do to get it to work like it did in vdj5?
geposted Sat 06 Jun 09 @ 4:24 pm
And corrected in the quick fix that was released ... 6.0.1
geposted Sun 07 Jun 09 @ 9:10 am
is it also fixed in the demo available here? ´cause it doesnt work for me.
geposted Sun 07 Jun 09 @ 11:44 am
You need to run the BCD in B-DJ mode not advanced.
geposted Sun 07 Jun 09 @ 12:32 pm
sorry, first of all thanks for your help.I really apreciate it.
But i dont know what you mean by B-DJ mode. I cant find anything thats called so. To make things a little bit clearer i´ll try to describe what happens with each setting the bcd control panel offers.
ASIO standart: works just like expected, except for the LED´s that dont work.
ASIO advanced: the first push on the LED turns the LED and the effect on, second push turns the LED off, third push turns effect off.
WDM/MME standart: like ASIO standart
WDM/MME advanced: like ASIO advanced
MIDI advanced: like ASIO and WDM/MME standart
MIDI advanced: first push turns LED and effect on,second push turns the effect off,third push turns LED back on and the effect off and the fourth push turns the LED off.
BCD Firmware 2.0
USB 1.2.0.0
ASIO 1.2.0.0
MIDI 1.2.0.0
Again everything works like it should, only the LED´s dont respond what really bothers me.
BCD Firmware 2.0
USB 1.2.0.0
ASIO 1.2.0.0
MIDI 1.2.0.0
geposted Sun 07 Jun 09 @ 5:21 pm
bump
geposted Mon 08 Jun 09 @ 10:52 am
Do not bump threads ... it doesn't get them solved any quicker ... once I have a resolution I will post it ...
geposted Mon 08 Jun 09 @ 11:20 am
thanks, now that i know that it is getting looked into i wont hesitate any more. I just didnt want the thread to be forgotten. no bad feelings, peace :)
geposted Mon 08 Jun 09 @ 11:34 am
Hi to all,
i'm informing that a new definition file a new standard mapper for the bcd3000 will be available asap.
There will be fix all the issue
geposted Mon 08 Jun 09 @ 11:41 am
