have a question since most computers are no longer using s - video i have an hdmi port and since the clubs i work at are set up with s - video out is there any products out there i can use to get my hdmi port out to s- video
geposted Sat 06 Jun 09 @ 6:13 pm
geposted Sun 07 Jun 09 @ 2:09 am
Yup, Apricon, Wireless nailed it. I have one of these just in case, and more often than not I need it for karaoke and playing music videos sets. Many clubs and bars still haven't upgraded.
DJ RuDe
DJ RuDe
geposted Sun 07 Jun 09 @ 3:10 am
they are expensive
ironically I bought a laptop and I insisted it had hdmi
I never thought that I too may someday need one of those adapters
it would almost be cheaper to buy a new netbook
geposted Sun 07 Jun 09 @ 8:55 am
Do you have VGA also? An adapter for vga to s-video is cheaper. What model system do you have?
geposted Mon 08 Jun 09 @ 9:12 am
i have a dell studio 17 they have no s video support its hdmi and vga out
geposted Wed 10 Jun 09 @ 1:52 am
geposted Wed 10 Jun 09 @ 1:54 am
I have a XPS m1330, with hdmi and vga. I use the KWORLD PC to TV Converter KW-PCTV-1600 VGA. It is small, light weight.
It has Composite, Component and S-Video out. It is powered by a USB port. It looks just as good as any computer with builtin s-video.
The resolution the manufacture says you can get 1600x1200 or something like that. I can get a clear 1024x768 out of it.
See:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100144&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Video+Devices+++TV+Tuners-_-Kworld+Computer+Co.+Ltd-_-15100144
$68 US. You might be able to find it cheaper.
There are others brands out there too, its not worth getting a HDMI to S-video. Right now I am using HDMI to a DVI projector (HDMI to DVI adapter). That looks the best so far.
DJ Kavika
See:
DJ Kavika
geposted Wed 10 Jun 09 @ 9:12 am
If You have a VGA port, Definitely go with an averkey product. I bought a cheaper unit off ebay for $30, but it only lasted a week. Aver key makes solid products...
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100005
This is the one I use. $70.00 bucks and works very well.
geposted Thu 11 Jun 09 @ 2:49 am
