hello guys...
i have a problem/error , every time i try to run some plug-in/effect the the software crashes and than that pop up comes and sais fatal error.....or it sais virtualdj.exe has encountered a problem and need to close...or it sais run time erro.....
plz help me i realy love to djing whith this
geposted Sat 26 Mar 05 @ 5:03 pm
Please post your computer configuration (CPU, RAM, ...) and version of Virtual DJ that you are using.
Regards.
Regards.
geposted Sat 26 Mar 05 @ 5:06 pm
sure mate , here you go...
Virtual DJ version 2.06 , pentium 4 , CPU 2.40Ghz , 256 MB of RAM
geposted Sat 26 Mar 05 @ 5:11 pm
2.06 ? How did you get it ?
geposted Sat 26 Mar 05 @ 5:28 pm
lol..
geposted Sun 27 Mar 05 @ 6:26 am
Well TRANCERO the problem is obvious. This forum does not support unofficial versions of VDJ.
Solution: Download a trial version of VDJ (2.05) from www.download.com, it will work without such problems :)
geposted Sun 27 Mar 05 @ 11:18 am
Tum tum tum...Another one bites the dust......
geposted Sun 27 Mar 05 @ 11:33 am
