Hey guys,
Basically I just need to know if I can use all the functionalities (effects, loops etc) of my CD players (Denon DN-S3500) when I use time code CDs and run VDJ.
Ryan.
Ryan.
geposted Sun 07 Jun 09 @ 5:53 am
Any help?
Surely its an easy question..
geposted Sun 07 Jun 09 @ 5:08 pm
Effects no, looping yes.
You can't use the effects since the actual track you play won't come out from your CD-player, it comes out from the sound card of your computer. Your CD-player will only output timecode signal.
You can use loops (and cue points) as long you set the start/end point manually. Auto-beatloop functionality, such as in Pioneer CDJ-800, will not work.
geposted Mon 08 Jun 09 @ 4:17 am
