I am having a problem out of no where. my HC 4500 was working fine with vdj 5.2.1. i have not updated to 6.0 yet. I am not sure if i am at the moment. but the issue is that i can't see the song on the monitors on the 4500 anymore. It was there before and no longer is. Is there some feature i am missing to get it to see the mp3?
Thanks for your help!
geposted Sun 07 Jun 09 @ 2:25 pm
sounds like another one bitten by 10.5.7 updates.
geposted Sun 07 Jun 09 @ 9:05 pm
ya that is what i just found out. now i am trying to see if there is a fix for it! have you heard of any?
geposted Mon 08 Jun 09 @ 10:06 am
Same here, Waiting for a fix and a explanation how this is possible, or how we can work around it.
I want to get busy again with vdj and my HC 4500.
geposted Tue 09 Jun 09 @ 1:08 pm
the fix is to get your osx's discs out and roll back to 10.5.6
geposted Tue 09 Jun 09 @ 1:52 pm
Yes, i know that should work. But it's not a fix/update. I read between your lines that this will not be solved very soon.
So i will do so. Thanks for your reply DJ Cyder.
geposted Wed 10 Jun 09 @ 12:39 pm
well apple says its denons fault and denon says its apples fault. I'd say get your disks ready until we hear something other then blame.
geposted Wed 10 Jun 09 @ 1:21 pm
