Hi all, I just installed Virtual DJ 6 demo for PC.
I'm using two sound cards and VDJ is setup to use two cards. Both are working, however the 2nd card which is for headphones preview, only allows me to hear the track on the 2nd deck, but not the first and 2nd simultaneously.
In the previous version there were crossfaders on the top toolbar to allow both tracks to play, but not in VDJ6.
How can i fix this issue?
geposted Sun 07 Jun 09 @ 3:26 pm
In the mixer panel of the new skin, there is a knob named "cue" right under the main volume. This replaced the slider on the older versions.
geposted Sun 07 Jun 09 @ 3:54 pm
I noticed that knob and adjusted it, but i still cant hear both tracks in the headphones. When i adjust the cue knob, it just adjusts the volume of the 2nd track. Any other settings im missing, or something setup incorrectly?
thanks
thanks
geposted Sun 07 Jun 09 @ 4:08 pm
any other ideas on this issue?
geposted Mon 08 Jun 09 @ 5:55 pm
Has anything changed in the way that you set up the two cards in V6?
geposted Mon 08 Jun 09 @ 10:29 pm
No i have them setup the same exact way.
geposted Wed 10 Jun 09 @ 11:02 pm
Go to the VDJ5 skin move slider cue at the top to middle and then change back skin to VDJ6 and both decks can be heard thru headphones
geposted Sat 12 Sep 09 @ 7:43 pm
