hey guys after doing a check and clean ive lost some songs is there anyway of getting them back.also keeps saying i have hidden files but all my folders and subfolders are all set to show hidden files.how do i find the hidden files without having to search all one by one
geposted Mon 08 Jun 09 @ 8:17 am
You can now create two Filter Folders to help you out ...
UTILITY FILTERS
Filter string -> insearchdb=0 In my database but not in Search (Hidden from Search)
Filter string -> ispresent=0 Entries in my Database, but not on disk (Error: files) files deleted external of VDJ but have an entry in the database.
pg 22 in the V6 User Manual
UTILITY FILTERS
geposted Mon 08 Jun 09 @ 8:42 am
There's a new utility filter that will list files in your database but hidden from search. Create a filter folder with this: insearchdb=0 and it should list them for you (page 22 of user guide).
geposted Mon 08 Jun 09 @ 8:47 am
Oops...too late...duplicate...sorry!
geposted Mon 08 Jun 09 @ 8:48 am
Is filter folder same as a UTILITY FOlder?
geposted Tue 09 Jun 09 @ 8:29 am
YES
geposted Tue 09 Jun 09 @ 11:30 am
That "present but hiden from search" doesn't make sense to me. Could someone explain it?
How do files get in there to start with?
geposted Tue 09 Jun 09 @ 12:40 pm
Because people added the files to the search then at some point removed them from the search ....
geposted Tue 09 Jun 09 @ 1:47 pm
I am having a problem where songs (only ones that are contained in virtual folders) randomly dissapear from the search database. Of course the one's in virtual folders are the important ones. I do the whole fix, recurse... thing and they may show up for a while but before I know it the system is back to hundreds of songs that are "present but not in the search database".
Is there a way to disable this feature or lock the search database?
Last week one of my guys was DJing a wedding and the first dance song was one that dissapeared. It showed up two days before when we were preparing. Luckily he was able to download the song to his iPhone.
I''ll try the new filter feature at least for backup.
geposted Tue 09 Jun 09 @ 7:39 pm
I have found one reason, how you can make unwanted "present but hiden from search" files...
If you are browsing an older playlists or history with some deleted, removed or renamed songs, or directory with some no longer working *.lnk files, these songs are automatically added into database as hidden!
geposted Tue 09 Jun 09 @ 8:09 pm
So it appears from the above discussions that this "hidden file thing" is NEVER of any harm as it ALWAYS is about files that are never used or needed anyway. That was always my concern.
Can someone tell me if the statement above is absolutely correct?
If so, I'll never have to think about it again. :)
geposted Wed 10 Jun 09 @ 7:24 am
