Can someone tell me what is going on to my folders? I just downloaded 6.1 version last night and my music folders I've created keep coming up missing!
I dont understand what's happening ,everytime I reopen VDJ it seems to snatch a new folder and I cant find it again, PLEASE HELP!!!
geposted Mon 08 Jun 09 @ 1:27 pm
What are the folders - Virtual Folders ? When have you run a Check, Clean or Fix on your database ?
Btw ... it's 6.0.1 ...
geposted Mon 08 Jun 09 @ 1:52 pm
they are my red virtual folders and favorites . and yes i meant version 6.0.1 sorry.
geposted Mon 08 Jun 09 @ 2:23 pm
geposted Mon 08 Jun 09 @ 2:26 pm
I also ran a database cleanup just today and none of the old music was from any of the folders
geposted Mon 08 Jun 09 @ 2:28 pm
it could be that multiple instance bug thingy.
so, restart computer.
open vdj, it should be there on the 1st instance.
geposted Mon 08 Jun 09 @ 7:21 pm
no luck it literally stold 3 folders lol............. so far it hasnt happened again though but, I have to rebuild from scratch and hope it doesnt happen again, damn!
Anyone else have any idea whats up with this??
geposted Mon 08 Jun 09 @ 10:40 pm
open your old VDJ, see if they're still there. if so, make sure the Virtualdatabasev5 is still in your VDJ folder in you documents.
geposted Mon 08 Jun 09 @ 11:26 pm
I no longer have the old version on my pc, but i looked in the documents and found the virtual database v5 inside. So, apparently it's there thanks , good try no luck.
geposted Tue 09 Jun 09 @ 10:47 am
