A shorter version.............how do i make vdj6 work with all my old shortcuts. tried deleting 5.0 for full insatll but still only some work.
geposted Mon 08 Jun 09 @ 2:12 pm
V6 has been re-written from the ground up. therefore many of the "action" commands from V5 no longer work as they used too.
You best bet is to start again - IMO
geposted Mon 08 Jun 09 @ 2:34 pm
thanks for the reply DAN. I even did that. the problem was getting one button to do 2,3 or even 4 functions.
geposted Mon 08 Jun 09 @ 3:47 pm
for 2 funtions........
1st button "eg shift".... set "my_var" 1 while_pressed
other buttons...... var_equal 'my_var' 1 ? my_action2 : my_action1
= 2 actions
for three functions......
1st button "eg shift1".... set "my_var1" 1 while_pressed
2nd button "eg shift2".... set "my_var2" 1 while_pressed
other buttons...... var_equal 'my_var2' 1 ? my_action3 : var_equal 'my_var1' 1 ? my_action2 : my_action1
= 3 actions
hope that makes sense, let me know if you need any help
PJay
= 2 actions
= 3 actions
PJay
geposted Mon 08 Jun 09 @ 4:20 pm
PJAY the combo you gave me worked but there is a slight delay.if you could solve that one for me i won't bother you no more my friend.i got all the rest just that one is left. cant get rid of the delay even tried adding nudge. thanks again
geposted Mon 08 Jun 09 @ 5:33 pm
