Is there a way to increase the pitch by pushing the pitch slider upward instead of downward?
Thanks
Thanks
geposted Tue 09 Jun 09 @ 10:26 pm
Hi
try......
param_invert & pitch_slider
Or...
pitch_slider
one goes one way and the other goes the oposite,hope thats what your looking for
PJay
try......
Or...
pitch_slider
PJay
geposted Wed 10 Jun 09 @ 1:06 am
PJay wrote :
Hi
try......
Or...
pitch_slider
PJay
try......
Or...
pitch_slider
PJay
Hi PJ,
How do you get to "Param, etc."
I have version 6 on my Vista DT and XP LT.
geposted Wed 10 Jun 09 @ 4:41 am
Do you mean change the direction on the skin? or controller?
geposted Wed 10 Jun 09 @ 5:40 am
Skin. I am trying to work only from the Laptop. Of course the signal goes to my mixer.
geposted Wed 10 Jun 09 @ 6:30 am
Which skin are you using?
geposted Wed 10 Jun 09 @ 6:34 am
Whichever skin you are using, you need to go into the folder where the skin xml file is....
open the xml file up in a text editor >>> scroll down until you see something along the lines of.....
Pitch Deck A
<slider action="deck 1 pitch" orientation="vertical" direction="down" dblclick="deck 1 pitch 100%" rightclick="temporary" >
then you need to change the .... direction = "down" ... to .... direction = "up"
then scroll down to do the same for
Pitch Deck B
if you have any problems, just let me know
PJay
Pitch Deck A
Pitch Deck B
PJay
geposted Wed 10 Jun 09 @ 6:48 am
The Version 6 Skin Dropdown gives only Skin Options. I see no way to alter skin functions there.
geposted Wed 10 Jun 09 @ 8:51 pm
You can't edit skin functions from within VDJ - you have to open the actual skin XML file in a text editor and change it.
geposted Thu 11 Jun 09 @ 7:38 am
You have gotten the answer you need, but I just want to comment on your topic title - - "Topic: How can Pitch Slider Direction Logic be reversed?"
And the logic is not reversed ... you are reversing the logic to accomodate what you see. You see things a up is greater and down is less, hence the reason you think logic is backwards ...
The pitch control is based around the clockwise rotation of the turntable. Pushing up or towards the back of the turntable in the opposite direction of the spinning platter, so you would be going against the direction of spin (visually) so therefore slowing down the speed. To pull forward or towards the front of the turntable you would be going in the same direction of the platter and therefore increasing it's speed.
geposted Thu 11 Jun 09 @ 1:46 pm
Thanks but this is sort of Greek to me.
What is the actual skin XML?
What is a text editor?
geposted Thu 11 Jun 09 @ 8:11 pm
Go into your skins folder, find the skin you want to change and unzip it.
You will be presented with a BMP and an XML file. Open the XML file in something like Notepad, make the changes, then save.
Open VirtualDJ and select the skin you just edited.
geposted Fri 12 Jun 09 @ 8:03 am
